JOHNQ wrote:my temp gauge needle is close to midpoint when driving in summer heat for long periods and im thinking about using this product. does anybody know if this works as it should and will it cause any potential damage in the future? whats everybody else needle with a 97-01 Q go up to when driving around in the summer?
None of the responses here make note of the need to clean the radiator and condenser coils FROM THE REAR. The air passages in both must allow good airflow to transfer heat from the liquid coolant to the cooling air that SHOULD be passing through.
Being careful to not knock any connections loose, blow the coils in the radiator and as much of the A/C condenser as you can access clear of dirt and debris from the rear (with the engine off). (Be sure to check for paper/plastic sucked onto the surfaces of the rad and A/C coils). Then, if you know what to avoid wetting, carefully use a high pressure wash/rinse wand at a coin-op car wash from the rear to remove the oily/greasy film that can accumulate on the rad and A/C condenser and collect a lot of crud.Be careful where you shoot that high pressure water; you don't want to force water into some connectors that could cause problems.
After conquering this issue, apply the same principle to the heater and A/C coils inside the car to improve performance of the Climate Control system. Just be VERY careful removing these components. Read up in the FSM and the many threads in this forum first to learn what to do and what not to, and what pitfalls to avoid. This CAN rejuvenate your Climate Control System and make it perform like new, IF you're careful and know what you're doing. It's not an easy 2 hour job like cleaning the radiator and A/C condenser correctly is though.
Another tip: Make sure all underbody airflow panels are firmly attached, and make sure the radiator shroud is tight and well sealed, all belts are tight and correct for the car, and that the fan assembly operates properly.
