has anybody put n2o in their spec v?
1gr8v
Car: 2002 sentra se-r spec v
I'm looking into a nitrous set up for my 2002 spec v. Does anyone know of any reliable kits that i can install?
nametakennow
Car: '06 MINI Cooper S
It's been done. Google it and go with a well-known brand, follow the instructions, and you'll be fine.
psifreak
Car: 06 spec v-T
dont run anything bigger than a 70 shot without a progressive controller
SeRated
Car: 02' Nissan Sentra Se-R SpecV
For our car you should definitely use a wet kit to play it safe, if you want you could do a direct port too!Most people use a 75-80 shot, some crazies run progressively controlled 100 shots. Wise decision to retard timing 2 degrees for a 75+ shot. Ngk Lfr6a-11 for copper or lfr6aix for iridiums spark plugs either one will work. NX EFI wet kit is pretty good from what I hear.Make sure you loctite your butterfly screws and get an aftermarket headers so you wont run into precat failure.
redtop240
Car: 92 240 RB20 Coupe
i used the venom set up. i just used a 50 shot and the power was awesome. i do recomend that to be on the safe side if its your first time to but the venovus ncm-2 its the best electronic system to protect against spraying with no fuel. you can set even what amount u want sprayed at what rpm.
B13_VE
Car: 1991 B13 Classic Se-R Neo VVL Powered
NX worked well...
