Has any1 heard of Gude Performance?
Scott McLellan
Just wondering if anyone has heard of Gude Performance found at http://www.gude.com/
Here's a cam set and its stuff:
PART NO.: NSCS05 DESCRIPTION: Awsome power increase from 4000 R.P.M. to redline. POWER BAND: 4000 R.P.M. to 7000 R.P.M. IDLE: (Good) SPECIFICATIONS: Intake LIFT - 0.420 DURATION - 226 Exhaust LIFT - 0.420 DURATION - 226
-or this package?
PORTED AND POLISHED CYLINDER HEADS KA24DE NSRH08 Just found it and was wondering if anyone had tried or heard of it before?
TrunkMonkey
Car: 2000 Lincoln Navigator
i haven't heard anything good about gude. all i've ever heard is that they are very shady.
-demetrius
240FeVeR
Car: 1992 240sx Coupe!
I would stay away from Guge after hearing one too many bad stories about them. Once they sent back a cleaned up stock cam as a performance cam, probably more than just once.
Syntax360
Car: 1986 Nissan 300ZX Turbo
EDIT: http://www.angelfire.com/pop/nizmo240/index2.html
that guy highly recommended them. said it was the best mod he did....?
sorry about that :-) too many links to keep track of....
Performance:Of all the performance products I have purchased, I would recommend Gude headers...it felt like it gave me a great jump especially above 4500 RPM. I wouldn't recommend buying it full price though, I got mine used for $150...haha!
TrunkMonkey
Syntax360 wrote:said it was the best mod he did....?
ummm...where?
there's nothing on that site that even mentions gude.
-demetrius
Dan
Car: soccer and speed
hey, I bought a gude cam back in 96. That was my first mod to my motor. There was a definate feel in performance. After 4000 rpm the motor kicked A$$. Me and my buddy used to race to work all the time, he had a jeep grand (dont laugh it was just for fun). He would get me when I hit 3rd, after the cam install I would walk away from then on. The only bad thing is the install of shims on your valve stems. Over the years, I ended up wearing the shims down very thin. Now, gude has gone to a different shim. there suppose to be stronger. My motor has 200K on it now. She's pretty worn.
king240
I have the gude header on my 92, bought back in 99, still going strong and works well, 4 into 1 design.
themadscientist
226 sounds like a stock grind, does anyone have the specs on the stock KA cams?:confused:
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
I know SOHC grinds: .407" lift and 228 duration. I believe Gudes SOHC was .500" lift and 228 duration, so basically the valves opened farther, but did not stay opened any longer. Now my Nismo cam is .402" lift with a whopping 270 rotation. Talk about a radical cam. There is so much overlap i got the Super AFR to buffer the incoming air flow meter signal so the car wouldnt stall out. But talk about power! (of course im still waiting, after 3 months of rebuilding my engine, to start the damn thing!)
Frankie1Eighty
so, clear this up for me. The nismo Hi-Performance Cam (.402"/270 Degrees) is NOT the 91' exhuast cam??? &Does anyone know if Jim Wolf has a more aggressive cam(E256 / I248 .422) for the Ka24e? which is the better cams out of these 2?
TrunkMonkey
Frankie1Eighty wrote:so, clear this up for me. The nismo Hi-Performance Cam (.402"/270 Degrees) is NOT the 91' exhuast cam???
no. the nissan motorsports high performance cam is for the E engine. the S13 dohc exhaust cam only applies to the DE engine.
just a note, it isn't just the 91 exhaust cam. it applies to all S13 DOHCs (91-94).
-demetrius
