LiU »
https://forums.nicoclub.com/liu-u490.html
Tue May 11, 2004 9:57 am
update (all by hand)ok used 600, 1500, 2000 w/ car soap water until it was transparent w/ a film of water over it.Then used turtle wax rubbing compoound, followed w/ megauir's #10 clear plastic polish.
results:looks stunning, no yellow, clean, clear, great job right??!
the problem:Then I rinsed the headlight w/ water and it seems the polish washed off, because the light became immediately less transparent, foggy (althought NOT yellow).... it is less transparent than the noncleaned one...
any tips would be appreciated! I'm tempted to try waxing the headlights, but I don't want to use that to cover (possible) errors in sanding/polishing.
