Jamaica2G »
https://forums.nicoclub.com/jamaica2g-u26509.html
Thu Dec 15, 2005 4:34 am
05 6MT G as well...I have the same exact problem.... just learn to shift harder! I know it doesnt sound like it is the answer, but it helps a lot.
I get a clank sometimes from 5th to 6th
and if I didnt shift it hard enough, I would get a grind sometimes from (with clutch to the floor):6th to 3rd, 1st to 2nd, and 2nd to 3rd.
After shifting much harder when driving hard, I hardly have the grinding problems anymore, save for the 5th to 6th clank. Next time I take it to the dealer I will complain as well.
If you do searches on other forums, you'll find out that this is the 6th or 8th generation of this transmission by Nissan (I can't remember which number). The shifting has been notchy and grindy from the very beginning on the z's and g's and up to now the problem hasn't completely been solved.
You'll also read that many end up having their transmission completely changed at the dealer! It is this reason why I have not put in a short shifter kit on the car. I want all OEM parts that I can blame on the manufacturer.
Good luck, and as C-Kwik said, be observant.
Keep us posted!
Adrian
