Harness tucking fun!
Odysseus
Car: '89 Sileighty
So I am gonna be buying Stance GR+ Pro coilovers and Circuit Sport RUCAs/toe arms very very shortly and thanks to some of you in the technical section I decided to tuck my harness so I dont burn through it. It was my first time really taking apart my car like that so it was a nice learning experience.
Fenders off, harness in stock spot
At this point I was wondering what in the hell I got myself into
Loose harness
Tucked and tied
Fenders back on
So yeah, getting it all off was cake..Half hour job including tucking the harness up. Getting the fenders back on and aligned. TERRIBLE! Took me hours haha...The harness made the fenders fit alot tighter. The passenger side was a smaller harness so it was easy but the driver side I had to remove the plastic cover and then I re-electrical taped it. That made it smaller and then it fit.
I noticed that the conversion was half assed too. Im missing so many nuts and bolts it was stupid. Half the **** wasnt even finger tight. So I completly re-did it and its almost golden...
Lastly....I know I have to hammer a little lip flat so it doesnt shred my tires. Is it that skinny thing hanging down? I dont wanna smash up the wrong thing..
I think I should make a build thread haha
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
looks good, should change back to pop ups to make up for that half assed conversion:) sileighty not so hot imo. glad to see your going the right way on the tucks tho, i would take it farther with the engine bay too. good luck with your direction and the car.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
should have done it after you put on the suspension to see if it's needed. but I guess, you are planning to slam down the car.
Odysseus
Car: '89 Sileighty
I <3 Sileightys hahaha...Thanks though
And yeah I didnt wanna dump my car and then burn through my harness so I figured I would just be safe and not sorry and not have to worry about it...
sebazztard
stutterr
Car: 1990 240sx
Nice, thanks for the pics, gonna do this once it get a lil warmer to my hatch. Good job on tucking.
Your tires rock!
Amateur Rally Winter Tires FTW!!
touge_951
good job
S13Teddy
Car: R32 Skyline, S13
nifares240 wrote:should have done it after you put on the suspension to see if it's needed. but I guess, you are planning to slam down the car.
That's not too smart. By the time you realize that you will need to relocate it, it's already too late. Plus, it's not a bad idea to do it, regardless.
onosqv
Car: '92 240sx Vert
looks like you haven't pounded in the seams yet, you should do that too to avoid hitting your tire.
The obvious ones are... well, obvious: above the tire, firewall seam, and one running along the inner wheel well between the lca & tie rod.
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
I wish it were this easy on the vert.The stupid fender brace gets in the way a wee bit if i recall correctly. (I havn't touched my vert in months )
Odysseus
Car: '89 Sileighty
Which of those do I pound flat? You said something about the firewall but that little lip seems really far back...
ArcherV20
Car: 1995 240SX
If you're talking about rolling your fenders, you'd be pounding the lip on the inside of the fenders flat.
derrick113
Car: '91 Hatch SR, '93 Vert
top seam directly above the wheel, the back ones will be fine. Take your time, i heated the metal up some first. Dont forget to use some sealer (paint / clear) to cover up and bare metal spots then to avoid rust.
onosqv
Car: '92 240sx Vert
derrick113 wrote:top seam directly above the wheel, the back ones will be fine. Take your time, i heated the metal up some first. Dont forget to use some sealer (paint / clear) to cover up and bare metal spots then to avoid rust.
They aren't fine if you run what I run, hee hee.
Odysseus
Car: '89 Sileighty
No I dont mean rolling my fenders. I mean inside the wheel well there is a metal lip that you are supposed to pound flat so that it doesnt rip up your tires when you go low.
I think I know which one it is..Its kinda obvious...And good thinking heating up the metal. I was just gonna use vise grips to bend it and then hammer it flat...
derrick113
either im not baller enough then or you have some massive tires haha
MastaYu
Car: 92 Nissan 240SX SE HB
i need to pound in that seam also
Matej
Both.The side one might not be necessary depending on what size and offset your wheels are, but you might as well do it just to be safe.
My harness rubbed the worst when I had just shocks and lowering springs (Sportlines), under body roll. It wasn't as bad with coilovers since they're a lot stiffer, even though the car was a lot lower, but I still waited too long and ended up having to replace the entire chassis harness, and also the interior harness.
I moved the chassis harness from inside the fenders to the engine bay, I don't feel like dealing with wiring again anytime soon, haha.
Modified by Matej at 7:12 PM 1/11/2009
LuckyDerDer
Car: 89 240sx
nice looking mini project, oh and it looks CLEAN.
White Comet
Car: fc, s13 and mazda6, Sierra
not bad, but for anyone doing this in the future it might be best to bend the little lip down so that the harness doesnt rub when you move it farther up.
Odysseus
Car: '89 Sileighty
Thanks fellas!
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
yeah its this little bastard that got me once already..i just took a flat body working hammer and rolled it back onto itself. tucking is a ***** :[. just wait till you move in and try to tuck the engine harness..i'm a week into splicing/lengthening/shortening and soldering it together the right way
White Comet
when it was still warm out i was working on my wiring tuck with mrgreeneyes. he's the man with wiring. a lot of people are too intimidated by it though. after my car's back on the ground i'll finish the tuck, but theres a reason teh bundle of wires is so thin in my pic
