Harness identification
SCBiggie
Car: 1992 Nissan 300ZX N/A 2+2
Hello all,
1992 N/A 2+2
I'm hoping the pros here can help me identify quite a few (5) disconnected wiring harnesses in the engine compartment. I bought the car running pretty rough and have since gotten it stop throwing ECU codes and I seem to be at full power. I was getting code 34 and decided to relocate the sensor until I can repair it properly. In doing so, I found these connectors just dangling free in the engine compartment. Any insight would be greatly appreciated. *There's no telling what was hacked up/modified before I bought the car.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
1st pics is the cruise control stuff, looks like its removed. You can see the 2 empty bolts in front of the battery.
Middle 3 pic are for the AIV system and EGR, probably removed also, common deletes
Last pic by the BMC is for the PRVR, probable removed also, common deletes
SCBiggie
Thank you!! Really appreciate it
