The harness bracket piece between your legs and the ones on each side of your seats are bolted to the SHEET METAL UNDER THE FLOOR just as in my race car and is approved by the SCCA. (Guess whos going to chime in next!)TunerTrifecta wrote:I may only be 19, but I've grown up around cars and motorsports lol
Do NOT install your harnesses to the floor! DO NOT! Harnesses need to be at less than a 45* angle to your body.
I have seen many a cars roll/crash out at the race track. Some with roll bars, some with just the roll hoop. Actually there was a miata that just had a roll hoop in it and crushed the passenger side of the car. Thank GOD there was no passenger and the driver was dazed, white as a sheet, and otherwise ok.TunerTrifecta wrote:Honestly, it's going to depend on how much you track the car vs how much you daily it.
Track more: I would honestly get a cage. It'll give you WAY more protection in a roll-over or even a "shiny-side-up" crash.
Daily more: Definately Roll bar. A Harness bar isn't going to do anything more than hold your harnesses down and give you a little more structural rigidity. A roll bar or even a "rear-cage" where only the rear of the car is caged would be ideal.
OK, well I think most of the people that posted in this are concerned for his safety. If you mount those below a certain degree point, you will compress the discs in your back, and this is how most serious spinal injuries happen. I know sparco sells a harness bar, but still depending on your skill level, it might be worth saving his money up and gettin a roll cage.TunerTrifecta wrote:Sorry for getting your panties in a bunch, I was referring to the shoulder harnesses; I guess I should've been a little more specific
Yes, you can get more head room by removeing the oem seat track and bolt the seat directly to the frame under the floor. You may have to have custom brackets made if a seat lowering kit is not available for the oem Z drivers seat. The best way to go though for greater support and safety on the track is to install a racing seat with a fixed position for YOUR height and leg room. The seat is lower without the sliding mechanism and also lighter than stock. You obviously give up the feature of moving the seat back and fourth. A performance shop can mount it to fit you to a tee, unless your really tall!! There are also seats made as a "street and track" version that are easier to get into on a daily basis vs. a track only seat.matt_2036 wrote:But again the problem remains. I am to tall to sit in the front seat, even with the roll bar, and not the full cage. It makes the seat not go all the way back. Anyone have any other suggestions?
, thanks for your help! Now I just need to find a shop in Charleston sc that does that sort of thing. Unfortunately they are all specialty here, i.e. porsche, European in genera, mitsubishi, subaru ect. I have yet to find a place that works on z's, or just Nissan's in general. And you all being Nissan owners already know what our service at the Nissan dealerships is like.PerfectApex wrote: Yes, you can get more head room by removing the oem seat track and bolt the seat directly to the frame under the floor. You may have to have custom brackets made if a seat lowering kit is not available for the oem Z drivers seat. The best way to go though for greater support and safety on the track is to install a racing seat with a fixed position for YOUR height and leg room. The seat is lower without the sliding mechanism and also lighter than stock. You obviously give up the feature of moving the seat back and fourth. A performance shop can mount it to fit you to a tee, unless your really tall!! There are also seats made as a "street and track" version that are easier to get into on a daily basis vs. a track only seat.
