Well said. I know harness bars are tempting because they're inexpensive, and harnesses look cool. A lot of people go that route. But as a fellow track rat, I also recommend not doing harnesses without a roll bar. With stock 3 pt belts, you are much more likely to survive a rollover than with a harness because with 3pt belts, you can duck if the roof collapses.ldstang50 wrote:google is your friend, plenty of info on there
As a track junkie and auto-x instructor I do not recommend running harnesses or a HANS device without atleast a 4pt cageIf the car rolls and you are strapped in with harnesses and wearing a HANS but do not have a cage, the roof can collapse and crush you in the car. Running stock belts will allow you to 'move' out of the way.
I was looking at the Autopower 4 pt weld in too. Can you please give us some feedback when you get it installed?350Engineer wrote:I know you said you dont want a roll cage, but I also think that is your best bet. You can get a simple 4 point cage with a harness bar for $450 from vividracing.com. Its what I am going to get before my next track day in April. It also make sense because a harness bar will cost you $300 - $400 and if you can get a roll cage with the bar for $450 then thats smart. Check it out: http://www.vividracing.com/cat....html
Sure Ill gladly post some pictures and tell you what i think of it. It should be done by mid April.Bubba1 wrote:
