eddiec »
https://forums.nicoclub.com/eddiec-u12233.html
Sat Dec 24, 2005 2:45 am
looking at the fsm shows only one connection between the hicas control unit and the ecu. and that is for engine rpm. which tells me that the two systems are seperate and do not depend on each other to work properly.
so i am 99.9% sure that yes you will be fine using the hicas ecu in your non hicas car.
while your at it you may want to switch out the steering rack as hicas racks are supposedly a little quicker in their turning ratio.
