harmonic balancer
1995Q45havoc
Car: 95 Q45
does anyone know where i can purchase a harmonic balancer myns has a slight twitch to it and how much one would go for
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Have you called
http://www.infinitipartsusa.com
as they have an additional 7% off their standard 25% off sale this week.
Raxephon
Car: '04 RX8...for the moment...
Has anyone came up with a lightweight Non-Underdriven crankshaft pulley option?
Preferably one made out of 6061 aluminum and has the room for the factory weights to be installed.
I remember a set awhile back, but unless I am mistaken, they were underdriven.
Mainly because the cast craptastic crankshaft pulley just doesn't cut it.
qship96
Car: 1996 Infiniti Q45
Doesnt cut it for what? Certainly the factory pully has not caused many problems for members on this board? I have never had any issues in 224,000 miles with the pully- what are you trying to solve ?
A solution in search of a problem??????
1995Q45havoc
Car: 95 Q45
its not a huge deal but my pulley has a little shake in it and im ocd about my car running perfect so i was looking around couldnt find noone that has it...did not try infinitiparts tho...wish they made a performance one for the car that be nice
Raxephon
qship96 wrote:Doesnt cut it for what? Certainly the factory pully has not caused many problems for members on this board? I have never had any issues in 224,000 miles with the pully- what are you trying to solve ?
I don't like flaky brittle things.
Any pressure put on the edges of the crankshaft pulley will result in chips/chipping since they used a casting method for it as opposed to a billet or forged method.
I dropped the 6061 SR20DE pulley I have and it chips away the concrete in the garage.
Drop the VH45DE pulley the same way and you'll be lucky to have anything halfway decent left to use.
qship96
My Q has only had the crank pully off 1x in 13 years/224,000 miles- just 2 weeks ago, to replace the oil seal- dont see the reason to handle it enough to cause the concerns you have?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Did you happen to measure the stock balancer weight while it was off?
What is the weight of the 6061 aluminum?
I ask because the less weight that spins the more power you can gain, But it would only be 1-2 HP max I think.
Raxephon
Haven't found anyone with a G50 lightweight/6061 aluminum crankshaft pulley, and the SR20DE one that I have isn't even comparable.
Bu being that the stock G50 pulley is cast, having one made out of 6061 aluminum would definitely be lighter.
Infinitiguy19
Is it possible to have them custom made, New Group buy.
1995Q45havoc
Car: 95 Q45
i would love nothing more than to have one custom made but my pockets probally wouldnt like that...custom made one probally go for 400 to 500 bucks
Infinitiguy19
Well that would be a huge waste of money, I would not pay any more than $50 shipped for 2-3 HP max.
Q45tech
Then you are dreaming! As historically EACH legal added REAL [accurately measured] HP runs $100 -$150 except for ecu A/F software mods. Something G35 owners are find out now.
Anyway the diameter has more to do than the weight, something as small as the crank pulley radius is minor since it is less than the stroke length [3.256"] vs something large like a flywheel [why the Q unit is so light considering diameter].
"A flywheel is a mechanical device with significant moment of inertia used as a storage device for rotational energy. Flywheels resist changes in their rotational speed, which helps steady the rotation of the shaft when a fluctuating torque is exerted on it by its power source such as a piston-based (reciprocating) engine"
When you have only 4 spurts of torque lasting less than 40% [combined] in an rpm you must be careful to smooth out the other 60% of the rotation time.
Infinitiguy19
This topic has more info on flywheel weight aand any possible gains and losses: zer...re-hp
That helped me out a lot.
captainluigi
Car: 1996 q45t
Send it to California and they will index & R & R the much degraded elasomeric rubber. DO NOT REMOVE GRAM WEIGHTS WITH OUT MARKING WHAT WHERE! Mine is now smooth as baby butt & all for $115.00 round trip.SEARCH!!!!!!
P.S. Locate a big a** torque wrench, you will need it.
Trumpkin
Car: 1995 G50
Paul Wall wrote:Is it possible to have them custom made, New Group buy.
Talk to wes, he tried it once. With bad results!
