goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Fri Apr 18, 2008 8:11 pm
It looks like I didn't read your post close enough to see that you can visually see your crank pulley out of balance. I was focusing on the rpm range and transmission mounts.
I've only got experience with my Q's but when I changed the transmission mount and exhaust hangers at 125K the transmission mount was flat and the rubber on both exhaust hangers was torn. I had vibration at around 2200 rpm in 2nd gear (45 mph) and in 3rd gear (60mph). I think it's like all the other rubber suspension components we replace- you don't realize that you have vibration until you replace the part. transmission mount, exhaust hangers, sway bar bushings, struts, bump stops, upper links, tension rods, engine mounts (haven't done those). At 127k miles you'll see improvement with every piece you replace.
Get your pulley taken care of and if money's not too tight go ahead and do the transmission mount and hangers. The parts are about $150-$175 and if I can do it in an hour laying on my back under the Q a shop shouldn't charge you more than that to change it on a lift. If you're a DIY'er it's a righty tighty, lefty loosey job. Very easy.
Since you're in La Jolla think about getting in touch with Jay (3Q Jay), Percy (Q45man?) and Tom. They get together (meet) every few months in the South Bay area for breakfast to talk Q's and would welcome another Q owner. They're meeting in the next week or two so the timing is right. For a benchmark, take a ride in Jay's Q to see what they felt like new.
