Aussie Q45a »
https://forums.nicoclub.com/aussie-q45a-u28894.html
Sat Apr 01, 2006 4:09 pm
I read that the Harmonic balance has to be tensioned to 270ft/lb's. I've tried to stop the engine from turning but without success. Where do I get leaverage with the belt wrench around the pulley without busting somthing? Somone suggested a screwdriver in the flywheel, but I can't seem to see where to put it.I got about 120 ft/lb on it using the metal bracket over the p/s pump as a anchor point for the belt wrench before the metal bracket over the power steering pump gave way and the handel on the belt wrench busted.Anyone got a pic of where to put the screwdriver in the flywheel?
Guess I should mention that I've just done the Chain Guides. Luck has it, they were all in one piece.
