hardly no air coming from ventilated seats
scchuck
Car: 2006 M35x
I just purchased a 2006 M35x and there is hardly no air coming through the seats. I have replaced the filters under the seats, but still only very little air is felt when the switches are set to high.
I used to have a Ford Expedition with ventilated seats and you could really feel the different air speeds. When I set the M35x switch to low or medium, I can't feel anything, and just a very very little air movement on high. Any ideas?
Steve
antzrus
Car: '06 M35x Premium/Obsidian/Bourbon/
Rosewood/XM/Tint/
ClearBra/SteelSkidPlate/Genuine CoCo Mats/Michelin CrossClimate2/Nav Hack/M-1
scchuck wrote:... Any ideas?
Steve
Yeah, welcome to the '06 "heated and air conditioned seats..."
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
Is it that you "don't feel air" or that your seats don't get cold after a while? Because there is a difference. They should get ice cold without "feeling air". After all, they are seat coolers not seat ventilators.
... yes Antz, they do take longer to ice than I'd like - but better than nothing!
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
can you hear noise under your seat? if so, you might want to check to see if the perforations in your seat cushions are clogged up or blocked, i remember one of our old members who did a swap out of his seat cushions/foam noticed that the foam infiniti used was very "breathable" so that could be the problem too.
scchuck
Car: 2006 M35x
Thanks everyone for some great ideas to check. Actually the seat does get cold, I was just expecting the 3 position switch to be "fan speeds' instead of degree of coldness.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
scchuck wrote:Thanks everyone for some great ideas to check. Actually the seat does get cold, I was just expecting the 3 position switch to be "fan speeds' instead of degree of coldness.
The the position switch is fan speeds in fact and be sure a/c is ON if its not in the on position and set to cold temperature as well already! :gotme
yosM45
Car: 2006 M45 Sport Twighlight Blue
Actual air should be coming out. Should should feel it up your back.
BUT, the air does come out via ventilated breathable tunnels/tubes that is built into the foam. Depending on weight and use, the foam in the seat will collapse, and therefore reducing the amount of air flow. Due to the breathable foam, the seats will still get cold, but the amount of air flow will be reduced with age and wear.
CONSIDERING that you know the fan is blowing, then your best option is to replace the foam on the bottom of the seat with a new piece, or find a junk with an 07, 08, 09, climate controlled seat, with low miles (little use) and replace lower seat cushion.
My 06 used to blast air on high, I felt it on my back, butt, and crotch/hamstrings. Now, 7 years later, it feel very low air on my lower back. That's it. And seat cushions are not covered under the extended warranty, only the ventilation components.
Hope this helps.
scchuck
Car: 2006 M35x
yup, that is exactly what I got. Just a little air on the lower part of my back. I am overweight so this is probably the issue.
Thanks to all!!!
Steve
