Hardened Clutch Fork Pivots
Nismo_Freak
Car: 89 Nissan 240SX
Just to let people know we now have hardened clutch fork pivots in stock.
Forged chromoly SCM435, black oxide finished.
$29 shipped.
If you'd like to order one, feel free to order online at our website with your paypal acct., or email us at [email protected], or give us a call at 1-866-SPL-PART.
fanta
Do you have stronger clutch forks?
float_6969
Oohhhhh, NISMO copy... I've got true NISMO ones. These are a must people I've broken 3 of these with STOCK clutches. The hardened one seems to be holding up well with my stage three though...
Nismo_Freak
float_6969 wrote:Oohhhhh, NISMO copy... I've got true NISMO ones. These are a must people I've broken 3 of these with STOCK clutches. The hardened one seems to be holding up well with my stage three though...
Z32's go through them like candy sometimes.
And no we don't have uprated forks, sorry.
fanta
Any idea asto how much stress the stock forks can withstand?
nab911
Car: 93 Nissan 240SX SE
How do you break the pivot ball? Does it just wear down or what... and can it be changed without a transmission pull?
float_6969
Ok, if you look at it there is a "head" on it. That is what breaks off. And no, I don't think you can change it with out pulling the transmission.
nab911
Oh, well if my bad *** spec stage 3 clutch lives up to its name, ill give you guys a call in 3 months :(
Nismo_Freak
Yeah, in all fairness this is something I'd suggest ordering when you do a clutch swap.
BoroBoroS13
Car: S13, RS13, and S14
I broke mine and ****ed up the clutch fork too... Damn 3 pluck clutch is evil.
fanta
Use a "street" disc, avoid pucks for street cars =/
float_6969
They'll still break on a street disk....
BoroBoroS13
But its sooo damn fun :P
fanta
float_6969 wrote:They'll still break on a street disk....
Yep, but the pucks are more than many need. Other things like to bust with pucks.
ahbongkeo
Car: 95 240sx se
what happen when the clutch fork break? cause right now my clutch is not acting right after a month of the new installation of my new clutch.
nab911
What do you mean by not acting right? And did you break it in right... is it bled right...
ahbongkeo
Car: 95 240sx se
everytime i change gear, the rpm would continue to climb like it was in neutral, but it doesn't go as fast. while the rpm goes up fast, the car still accelerate but slowly then it would catches and act normal. its like the clutch is slipping but only when i change gear. it happen only one time per gear.
Nismo_Freak
Sounds like you need to bleed the line.
float_6969
:withstup Did you take out that stupid secondary box that's in there? If not get a stainless steel clutchline and bypass that stupid thing. Nismo_Freak might be able to help you out...
ahbongkeo
Car: 95 240sx se
nismo_freak can u help me out....float_6969 say u might be able to
nab911
Find his other post, SS Clutch line, i had that problem forever and that line and a good bleed fixed it right up.
ahbongkeo
Car: 95 240sx se
what do i need to do to fix the problem? bleed out the system or install a new clutch line?
