hardbody window felt
RUE111
looking on internet for the window felts that seal window to the outer doors. anyone know where to get these?
longtooth
Car: 89 d21 HB
Found alot of weird stuff for me on ebay.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Got mine from the dealer. Expensive too. Never seen them on ebay.
RUE111
how much thru dealer.
JC87HB
Car: 1987 Nissan D21 HB
it was alot.. i know the dealer here in columbus wanted 500$... weather striping right?
RT22
Car: 1991 nissan hardbody
you looking for the rubber covered trim that clips to top of door or the felt that is on the window pads inside the door? The felt for inside the door can be gotten at a lumber supply place, they use self adhesive felt on cabinets to cushion the doors. The trim that is opn the top of the door, base of window to seal the window is high at dealer so junk yard it, the pathfinder of same yrs will work and can be found at junk yards replaced my dried out ones that way for 20 bucks.
Rev_D21
I paid about $50 per side for those. Mine were cracked and showing metal.
RT22
Junkyards are good but take time to find good ones, I had a buddy get some vinyl type paint remove his and redo them. it looked okay but I just hunted the junkyards until I found a better set than mine and then I soaked em in my auto magik dressing for a few days before installing to really moisten them back up.
RUE111
well off to the junkyards i go i guess. thanks for the info.
