Hardbody Trans Question For The Nissan Gods
rick_dizzle
Car: Hardbody
Hey guys I have a 96 Hardbody 4cyl 2wd. My transmission went nuts and decided to turn into a self contained blender of steel. My question is can I put a 240sx transmission in the truck? If so what year mods etc. I have researched this before posting with no luck. I appreciate the help guys/gals...__________________
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
Im assuming its a 5 speed? If so, the 240sx transmission is about 4-5 inches longer and a driveshaft will need to be fabbed, plus the shifter relocated. Other than that yes it bolts right up to your engine and you will need a 240sx starter as well. peace.
rick_dizzle
Car: Hardbody
nismopu wrote:Im assuming its a 5 speed? If so, the 240sx transmission is about 4-5 inches longer and a driveshaft will need to be fabbed, plus the shifter relocated. Other than that yes it bolts right up to your engine and you will need a 240sx starter as well. peace.
I did find out about the length and shifter location, I also heard about the front shaft having to be shortened as well.
THIS IS WHAT SOME OTHER USER GAVE ME AS INFO:Yes you can, I did it to my truck. You need to use the 240 flywheel and clutch assy also. I have a spare 240 flyweel if needed, but the shifter is going to sit farther back and you will either need to cut the bench seat to clear the shifter or get bucket seats. It bolts on and even uses the stock transmission mount location. The driveshaft will need to be shortened, the front shaft needs to be shortened 3" so the carrier bearing will be in the stock position and another 4" out of the rear shaft if its a regular cab and not extended cab. Heres a pic of the inside of my truck, note the shifter location
rick_dizzle
Car: Hardbody
BTW IT IS EXTENDED CAB 5-SPEED
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
it'd be a ton easier to bolt another truck transmission into it.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
But a 240 trans will make the truck wikid fazt!!!
rick_dizzle
Car: Hardbody
There are so many conflicting reports on this transmission. I know it will fit, the conflict is what mods need to be made. So I will probably stick to stock, unless there is a write up somewhere...ANYONE? I wanted the 240 trans for the different gears and the fact that they are like 50-100 bucks due to all the swaps going around.
nismopu
1997 Nissan Maxima
DAMMIT! I need to do an official picture post wit vids or something to keep the misinformation floating about. DONT ever go to the 240 flywheel and clutch assembly unless you really have to. The PP is not as strong and it is a smaller diameter, if you want a lighter flywheel then buy one from fidanza. I cant stand the people who put 240 clutches and flywheels in there pickup, MAKES ZERO SENSE. lol! The driveshaft info he provided however is correct, but he forgot to mention the starter when using the 240 transmission. peace.
rick_dizzle
Car: Hardbody
nismopu wrote:DAMMIT! I need to do an official picture post wit vids or something to keep the misinformation floating about. DONT ever go to the 240 flywheel and clutch assembly unless you really have to. The PP is not as strong and it is a smaller diameter, if you want a lighter flywheel then buy one from fidanza. I cant stand the people who put 240 clutches and flywheels in there pickup, MAKES ZERO SENSE. lol! The driveshaft info he provided however is correct, but he forgot to mention the starter when using the 240 transmission. peace.
Werd Bro, LMK if you make this tool available...that would be awsome..thx for the input...but for a challenged person like me pictures are awsome!...THANKS AGAIN GUYS!
