Hello, thanks for looking I could really use some good advice. I have a Nissan d21 4x4, z24, 5 speed. About 4 months ago a purchased a full tune up, plugs, wires, gas filter, distributor cap, the whole 9, and shortly followed that up with an oil change and new air filter. Since the tune up it has gradually started to sputter more and more. Now it seems to idle fine and doesn't sputter in neutral but it bogs down as soon as I put it in gear and hit the gas. Sometimes it would stop sputtering and run great when I put water in the coolant res, so i replaced a radiator hose which was dry-rotted anyway and flushed the radiator. Now this is interesting. I flushed a lot of mud out of the radiator and the block and it was definitely mud and not oil mixed with coolant. So i put it all back together and test drove it. The sputtering stopped completely and it started over heating and the heater stopped working, so i flushed it again and now I'm back to square 1, heat works, motor stays cool, but sputters like crazy when driving in gear.
Any advice you can give me will be greatly appreciated. Thanks, Tim
