Hardbody Rust solutions?
EROCK482
Car: 1997 Nissan Pickup
XE
4X2
4 Cyl
5 Speed
Teal with Beige Interior
Minimal Exterior Rust, Box and Bed are beginning to go.
My first vehicle is my dads 1997 Nissan hardbody, he bought it used way back when i was little, and its now become my vehicle now that i'm 16, within the past two years the bed has begun to rust and after this winter, the right rear wheel well is beginning to show rust, i'm curious if there are ways other than replacing the entire box, or cutting our rusted chunks and re-welding in new pieces, if there is a way to kill the rust and prevent its spread, and then repaint he wheel well with some touch up paint, and then apply a spray in bed liner to the truck bed.
I have heard of POR 15 and have heard mixed reviews, any help or insight would be amazing! Ill add some photo's soon.
Thanks!
Erock
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I like POR 15. Sadly the only way to kill rust is to cut it out. If you don't plan to make some patches your box is going to look funny with missing pieces. The other option is a used bed which is not a bad deal if you can find a decent one. I just sold one off my parts truck for $200 so there are deals to be had.
Check out www.car-part.com.
Kevkev1411
Car: 1986.5 Nissan Hardbody 4cyl 4x4 regular cab 5speed
What about sandpaper, elbow grease, rust reformer, and primer?
Rev_D21
It most likely rear its ugly head again.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Sherwin Williams Macropoxy 646
EROCK482
XE
4X2
4 Cyl
5 Speed
asoomal wrote:Sherwin Williams Macropoxy 646
Do explain please.
asoomal
It's a 2 part epoxy, really tough but takes a while for it to cure.
It cost me around $160 CAD for one gallon of hardener and one gallon of the second part. It'll completely seal out moisture since it's epoxy based.
When you use it, make sure that you thoroughly mix it and paint it when it's warm outside, it's kind of like spreading glue lol.
Also, they use it on boat hulls. :biggrin:
