Hardbody rim question
91nissanv6
Car: 1991 Nissan Hardbody SE-V6
Hey i was going to put 02 nissan xterra supercharged rims on my truck which is 17x8 with a +40mm offset. Am i going to have a problem with rubbing when i am turning?
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
I have 18x8+23 titans(225/45 up front) and I barely clear at full lock. I'm going to go out on a limb and say you will probably rub as a +40mm offset will mean the wheel sits farther in. You could just get some spacers though, 10-14mm should be just about right depending on your desired tire size and if your fenders are rolled.
