themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Sun Apr 12, 2009 3:08 pm
The title originally started "hardbody guys" but sound super ghey.
I have always loved the hard lines of the lil hardbody trucks. The styling reminds me of my RS and the shape is just right. I have almost bought one twice but for whatever reason it did'nt go through. I will be coming back in about 3 years and I need a truck, my lil Daihatsu is as illegal as a Skyline to import. Haters
The plan is start with a 4x4 short bed manual, drop it as low as I can and drop a hot engine in it. The goal is a Syclone killer. I always like those trucks but I think I can do it better. I would like some info about the truck from those who live with one every day.
I am not so much concerned with the engine unless that affects the quality of the drivetrain installed. I think a VG30DETT swap would be the most lethal motor to use, followed closely by a VG30ET, with a boosted KA24 bringing up the rear but still a potent choice.
1 drivetrain*any difference between the KA and VG transmission, transfer case, or axles? Any minor model change funny business wher certain years had better equipment? *Is the powertrain up to the task of drag launches in 4wd behind a 400hp engine? I have seen powerglide adapters for V8 swapped trucks, that gives me hope that it's tough stuff feeding power to the wheels.*I will need some highway gears I think. I will have low profile perfomance tires on at least 17" rims. I am not sure where the tach will be at cruising speed, 12,,,, I mean 55. Are wide wheels readily available in this bolt pattern?
2 suspension*How much would a 4wd drop? It's a hell of a lot easier to slam a 2wd, no front axle shafts and diff to contend with. I don't want a minitruck frame on the ground stance, just get the center of gravity down for stability.The torsion bars can just be tweaked to bring the nose down, axle over spring to drop the back? Is there a sway bar up front?
3 brakes*drums in the back and that's it? I hope not, I need real stopping power, the 50s are over. How does the front caliper mount up? Does it look like a set of 300ZX brakes wou fit on there?
4 reliabilityWhere do they break? Where do they rust? Any consistent defect I should be aware of?
thoughts, advice, encouragement, discouragement, good chili recipe?
