hard turn cause ebrake light on for couple second
i240sx
Car: 240sx coupe
when turning hard on a curve cause the ebrake light to light up for couple sec...what could be the cause of this...i check my brake fluid and its in he middle....any idea.....
jdm_240$x
Car: 1990 nissan 240sx
my 240sx did that and i added more fluid and the next day it was off..but try that and if it doesnt work try bleeding the brakes..
Pirate_Freder
Car: 1993 240SX Coupe
I haven't messed with my e-brake but isn't it actuated via a cable not hydraulically?
!Zar!
Car: Countless.
You need more brake fluid.
Sure it's half full at the bottom now.
But when you turn, what do YOU think gravitational pull does?
It moves all the fluid to the side and your sensor goes off.
Ugh. Come on people.
CRyan
Car: 1997 Nissan 240SX
Add fluid - Its not only the light that informs you the emergency brake is pulled, it also tells you if your low on fluid.
You should be covered afterwards
law
Car: 96 240sx
As a rule your fluid level is an indicator of wear on your pads. If your fluids low chances are your pads are also. Im a tech and the brake fluid is the only fluid i dont add to.
i240sx
Car: 240sx coupe
!Zar! wrote:You need more brake fluid.
i was thinking about it too....i'll add more fluid......
biggie
Could also be that the sensor is loose on the ebrake, have seen some like that. If the ebrake handle moves (you hit it or G forces cause it) then the sensor hits like it is engaged.
i240sx
Car: 240sx coupe
biggie wrote:Could also be that the sensor is loose on the ebrake, have seen some like that. If the ebrake handle moves (you hit it or G forces cause it) then the sensor hits like it is engaged.
where is the sensor located buddy???
biggie
Should be on the base of the handle. Been a long time since I'm looked.
Grab the handle and push/pull it side to side and see if that is the issue.
ricebike
2002 Quest
2005 Altima
law wrote:As a rule your fluid level is an indicator of wear on your pads. If your fluids low chances are your pads are also. Im a tech and the brake fluid is the only fluid i dont add to.
for the average daily driver
but but but......
he's taking hi G force turns, yo... and i assume he pulls off the wheels to check his brake pads before every track event <not>
Zar is correct on this one as well... just do one or the other & if you do put on new pads, might as well push the old fluid out of the bleeder screws if the fluid's dark
I tell my relatives about this same fact though, unless they have a fluid leak; then i recommend a visual inspection of all the parts & fix it
