hard to start when still at operating temp.
whoareu
Car: 1993 rb25det s2 240sx vert
So the car runs beautifully and if i turn it off and let it sit for 10-15 minutes it will typically start with no problem, but if i turn it off while pumping gas then try to start it when i am done say 5 minutes later, it will just crank and crank and crank. but after it sits for about 15 minutes it starts back up no problem. any thoughts on why this might happen?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Have you tried putting the gas to the floor when you are cranking it when it acts up?
whoareu
yes i have tried that. it makes no difference.
elwesso
2007 BMW M Coupe
have you tried anything in terms of diagnosing the problem, and have you replaced any parts recently...? When did this start happening?
mrflip69
coolant head temp sensor (CHTS).
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Coolant temp sensor cheech ohms when hot and cold. Then check MAF. I had that same friggin issue when hot. Also would die on me after coming off throttle at a stop lights. Shut off and restart. Ended up being the MAF.
whoareu
could be the maf. i do have that issue where if i gas it real quick then stop it will either try and die or die, and with this stupid issue going on now i cant restart it for about 15 minutes. lol. i recently fixed alot of vacuum leaks and am also having a funky electrical issue i am fixing this evening. i have a short in my main power wire where the distribution block is running to the battery relocate. silly car.
driftersilvia240sx
Car: 350z (business car)
240sx (rb25)
civic eg (winter beater)
i am having the same problem just with a hint of miss fire...Ill be ordering a new maf myself ill let you know if it helps
Carl H
why not try pulling codes to see if there is a stored issue?
