Lopin18 »
https://forums.nicoclub.com/lopin18-u58480.html
Sun Mar 16, 2008 1:40 pm
Soo im sick of testing around....
When the car is cold, i put the key on on, efan comes on normally, all hud lights normal, Try to start and it tries to crank mid speed, then starts slowing down real fast, lagging like 3 secs between crank spin sounds... sometimes tries to start like getting to it but puff slows, until it just Clicks, i try to start agian and its REEEALLY slow turning and puff clicks, then the efan sounds weeeeak, and the hud lights really weakened... Battery charge goes to crap... but if i put it a good battery VROOMMM real fast, also when its hot with my battery it starts real fast
i tested the parasitic drain thing, with a tester on the Negative cable (unplugged it from bat) and the negative terminal of the battery on the 9v Battery option (i didnt get any readings with any other option on the tester) and got around 9.Xv or sometihng, but i wonder... cause my battery was ok all lights ok efan spinning ok before i try to start cranking
Hmmm so what can it be???
also is the automatic starter usable on the manual transmission???
