ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu May 12, 2011 10:21 am
Towncivilian are they distributor-less? I don't have such a new vehicle, but do have a 31 year old Goldwing that uses no distributor, the electronic switch gear through transistor(s) becomes more vital. The state of the battery is vital to primary controlled electronics.
Can somebody post the ignition system on this forum for a look see?
Guessing what the problem is from the comfort of a nice chair is tough, on start up:
The engine needs compression
Air
Fuel
Ignition
in the correct order and the correct amount, plus the ability to crank over at the right speed range , so the battery is also very important to allow RPM, voltage for ignition. If a partially charged battery is used, these problems will exist because the voltage is drawn down by the starter motor.
Start the car drive around for 15 minutes at least and then park and read the voltage, engine off. Battery voltage should be close to 13 V then but never lower than 12.6. Start checking out the easy things first.
electrical as starter amp draw, gasoline supply, air, compression, then check into the more complex things as
timing, spark, heat range of plugs, plug condition, grounding
then get into control of:
timing, ignition, fuel ratio
Because the engine finally starts but runs rough, things that come to mind
Lack of proper fuel and pressure, too low voltage, lack of fuel enrichment as in choking, advancement in timing or a stuck mechanism instead of retarded setting, lack of air plugged filter, poor ignition wires, connectors, spark coils, bad negative battery cable/grounding.
These are a few areas that need a looking at.
Is that vehicle getting good routine maintenance? If not you are going to have to examine all aspects of the car since you are having intermittent problems.
