Hard to remove badges/labels from coupe?
All things Altima Coupe.
ram28
How hard and expensive is it to remove the "Altima" and "2.5" badges/labels from the back of the nissan altima coupe?
Hussain
Car: 08 Altima Coupe 3.5se CVT
i've never done it before but there are a lot of people who have and ill just tell you instead of a thousand people saying "thats what the search is for" (i hate the search too) lol pretty much what ive heard is that its very easy. take a blow dryer or hair dryer (what ever you want to call it) and a lot of people tried using floss to take it off. then just clean very good to get all the sticky stuff off and wax your car..... will look like it was never there
Rolling Estonian
Car: 2008 Altima Coupe 2.5
it's super easy and cheap.
What I did was1. spay alittle WD40 (optional just loosens the glue)2. heat it up with a hair dryer3. use the dental floss (or fishing line) with a sawing motion to take of fthe letters4. peel off the remainder of the tape (more WD can help)5. give the area alittle wax
LegendRacer
another point is Clay bar THEN wax
first the clay bar can help ensure all the layers of garbage is gone and the wax will protect it
Calgary35SE
Car: 2008 Altima Coupe 3.5 SER
I just did this today, took me 5 minutes to remove badges.Just take some fishing line run it behind the badges through the glue. remove excess glue, clean thoroughly and walaa
Radiant08
Car: 2008 Radiant Silver Altima 3.5 17in SE-R wheels, Fujita ram, more to come
It takes about 5-10 min. Dont spray WD-40 on your paint like the poster below mentioned. Not smart. Use 4 or 6lbs fishing line. Run it behind the badge and move it back and forth -- like flossing yer teeth. Then just take your finger and roll up the little bits of black rubber/tack that remain. No scratches, no chemicals - no worries.
Chinaman
Car: 08 nissan altima coupe 3.5
have anyone tooken the nissan one off the back yet? is it just held on by glue or is it like two holes holding it in?
Voodoo Coupe
Car: 08 Altima Coupe 2.5
the badges is simple i took mine off just by peeling them off no left over adhesive at all. the burger in the center Ive been told there is a hole. I'd love to take that off too but cant afford to repaint my car. spot painting blows when you have a winterFROST car that pearl is impossible to match.
HAD TO EDIT FOR THE SUPER COOL FORUM KIDS. carry on...
Modified by voodoo180sx at 8:36 PM 8/20/2008
Coupes4Life
Car: Altima coupe Code Red 2.5 and GT3071r Mazdaspeed6
I took my Alitma and 2.5s off with just Dental floss between the glue and the badge then wiped the excess glue off with my finger and washed it then but some wax on it.
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
i'm guessing u have a white car because there is no winter forest colored car its winter frost
spockrock
Car: Altima Coupe 3.5se
if you car is new, just take some strong fishing line and floss between the badge and glue, and then with your finger just rub off the excess rubber/glue. The wash the area off with soap and water.
Colton92
super easy. I just used some floss and heated the badges a lil bit with a hair dryer and they came right off.
Forrest80
Car: 2.5 CVT Altima coupe azure blue
let your car sit in the sun mid afternoon and let it get all super burning hot.
That made my double sided tape super mushy.
I used plain old dental floss and sawed back and forth on the letters and the nissan hamburger till it came off.
Then you just peel off the left over double sided tape and it comes off super easy for me in the heat.
Then wash, and if you have a clay bar thats great if not o well. mine left like zero mess.
ESP
Car: 2008 SexyBlack A/C
DO NOT USE WD-40 OR GOO GONE!!!!!!! I cannot stress this enough!
Even when the glue is cold, it's still pliable enough to peel it off with a soft plastic scraper. When you're done, make damn sure you wax that area well. I completely agree with the poster who mentioned taking a clay bar to the area, but failing that you should at least wax it.
Chinaman
so is there two holes behind the burger on the back or no? cuase i want to take it off
Forrest80
Chinaman wrote:so is there two holes behind the burger on the back or no? cuase i want to take it off
No holes behind the nissan hamburger on the back.
It is the hardest to take off compared to the others though becuase theres alot more tape used.
took me 20 minutes to take off all my back badges including the hamburger. My brother did it in 10 minutes.
sharpie
It's very easy, and it's free!
I took all the badges off, and the hamburger nissan logo and I think it made the car looks A LOT better!
bembol
Car: 2015 Nissan Murano SL AWD Cashmere Interior
Hair Dryer, Floss, Fishing Line...
Only need a Credit/Debit Card to remove the Emblems. Just make sure your Coupe is Dry.
ESP
sharpie wrote:It's very easy, and it's free!
INCOMING THREADJACK!!!!!Sharpie, what rims are you rolling on? They look really good.
sharpie
idk the exact style but they're Armano 20s
