CPS »
https://forums.nicoclub.com/cps-u98655.html
Tue Mar 03, 2009 3:04 pm
Couple of things. First of all, the reason Toyo probably can't get that tire is because Nissan has first dibs on them. The factory original Goodyear tires for most of the 04-08 Maxima's (245/45/18) works this way as well. As a matter of fact, the Goodyear store down the street from my dealership has bought them from us not only because we had it, but also because it cost him less to buy it from us (even with our markup) than he can get them direct from Goodyear. We have seen the same thing in the past with the older Murano tires, and also the Continentals that the 07 Altima came with.
Secondly, you could put your warranty in jeopardy by getting the size tire you mentioned. There is a slight difference in the size, and as you approach the 36k cutoff (or 60 on the powertrain, 80 on the catalyst) the dealer could very well run the size of your tire versus what came on it from the factory and add that mileage to your vehicle pushing you above the limit. I know it sounds like a stretch, but we have actually had a representative from an extended warranty company do this exact thing and has denied claims due to improper tire size. The reason for this is the amount of people who put oversized wheels and tires on their vehicle which creates a situation where the vehicle has actually travelled farther than the odometer indicates.
In your particular instance, the tire size you mention is 0.8% too slow according to the old trusty Miata.net tire calculator. So whatever mileage your vehicle shows, they will add 0.8% to that to come up with the actual miles travelled. At 36k you will have actually travelled 36,288. It's a minute difference, but it is still a difference. The real issues come up with people who run 22's and 24's or bigger, with drastic size differences, sometimes as much as 8 and 10%. Then you're talking about thousands of miles difference, not hundreds. Some of these guys are really starting to push this, so it's something to think about. Not to mention you are also talking about a tire that is 30mm wider that could cause a fitment issue and could change the way the electronic systems are able to control the vehicle in the case of an emergency.
