elpiar »
https://forums.nicoclub.com/elpiar-u47986.html
Thu Jan 17, 2008 5:05 am
My car (look to my sig for set-up) has trouble starting when it already reached operating temperature, but very easy to start when it's cold.
I replaced everything ignition related and upgraded to blaster coil. still nothing. My fueling is all perfect. Compression is perfect (new rebuild).
The only suspicion I have now is fueling compensation that is in the ECU tuning. Can you guys with 555cc or maybe other injector upgrade copy paste your fuel table for cranking?
In tunerpro I believe there are four of them, right? - Engine cranking Pulse width, - Engine cranking Additional enrichment, - Engine cranking Pulse offset- Engine cranking Ign timing
Can you help me understand these parameter and/or share your tune on these?
