Didderson »
https://forums.nicoclub.com/didderson-u38557.html
Wed Jan 23, 2008 12:12 pm
Hey guys I've been searching for days and trying things out here and there, but I can't get the problems in the title fixed. My car is quite tough to start when it's cold out. It runs at around 1500 rpm idle. I have no vaccume leaks, i used to at the bov, but that's fixed and it's still doing this: when I'm out of gears it will idle smooth BUT it'll dip from 1800 rpm to maybe 1200 rpm. Like slowly climbing toward 1800 and than, bwaaaaah, boggs to 1200, and climbs again.
I just found out today thru more searches that my oil weight is a bit off (I'm running 5W30 but it's winter here) I'll be changing that asap. I don't know what else could be my problem other than the IACV. I unplugged the iacv one time when it was jumping idle and it didn't change a thing.
Any thoughts? please help! I'm about to buy a new IACV if I can't figure this out!Thank you in advance.
also, the car doesn't like to run at low RPM's. sometimes i'll get it started but it'll be bubbling idleing at 8 or 900 and thankfully climbs back to where it's comfortable within 30 seconds.I set my timing DEAD ON 16 btdc but, I only set that timing at somewhere around 15 to 1800 rpm becaues my car won't idle. Would that affect my timing? i'm assuming no.
