hard to change AT?
Fenvy
Car: 2005 350Z Base 6MT
hi, I haev 1994 g20 automatic, a lot of times it will get not engage 3rd gear...
and it shift pretty rough with a nasty leak
so I am thinking about getting the auto transmission replaced. I found locally that someone has a 1996 g20 transmission for 100$
I was wondering how hard it is to replace auto transmission? would you say it is harder to change a manual transmission?
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
i don't like fwd setups to begin with, but an at should be just as easy to replace as an MT, with exception of weight. AT's are exceptionally heavier than MT's but the work is the same.
In the 240, to remove the AT you need to detach the torque converter, but you may have more room in a fwd to remove the AT without unbolting the Torque converter.
adrianfromthecastle
Car: 1992 Nissan 240sx
ugh... i used to have a 91 g20. if it was one thing i hated, it was it's AT transmission not wanting to shift up appropriately
Fenvy
MagikDragon wrote:i don't like fwd setups to begin with, but an at should be just as easy to replace as an MT, with exception of weight. AT's are exceptionally heavier than MT's but the work is the same.
isn't the torque convertor inside the AT housing? kind of like a fly wheel but ****tier?
I wonder if I can tackle this myself...
MagikDragon
no the auto flywheel is really light and is used to start the car. and the converter is the equivilant of a clutch and pressure plante assy, and is bolted to the flywheel. the TC is the link between the engine and trans. It used a centrifugal clutch to engage at a certain RPM.
Fenvy
okay, I am going to pick up tjhe transmission tonight.... is there a transmission code engraved on the transmission housing?
anything else I shoudl know about or look for?
