Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu May 20, 2004 9:02 am
BUT WHEN IT WAS LAST CRANKED [ Don't care if it sat for a month] HOW LONG DID IT LAST RUN? If you came in from a 15 minute minimum drive and turned it off and never moved it, that's ok, otherwise you may have created the problem with a short drive cycle.
FPCU = fuel pump control unit [3 speed pump motor controller].
The other thing to check is the fuel pressure decline as it sits for hours, days, years. There are antidrain back valves and the pressure should stay above 20 psi...........otherwise leaky injectors or something allowing pressure to dissipate......taking a few seconds to rebuild.
System designed to let the car sit at airport for at least 3 weeks.During cranking the ecu commands FPCU to go to high to rebuild pressure fast from 20 psi to 34 psi minimum.
