novasource »
https://forums.nicoclub.com/novasource-u106051.html
Mon Sep 15, 2008 5:37 am
I have an '02 Maxima. Consistently ran and started fine until I changed the battery a month ago. Since then:
*In normal Dallas summer weather (hot), starts fine on cold starts, but on hot starts RPMs will rapidly fall to 0 unless I nudge the accelerator to keep the RPMs over 1200 for at least 2 seconds.
*Today was the first day of fall-ish weather. Temps were in the mid-60s in the morning. Upon start, the vehicle ran very rough and died. Same with second start. I feared a mechanical problem. On third start, I nudged the accelerator and kept it running. After a couple of seconds at 1,500 RPM, I let off and it fell to normal-ish cold start RPMs. Driving off, I felt it hesitate off a stop a couple of times. I also may have heard intake backfires when accelerating from stops, but if so, it wasn't like a hard carburetor backfire I experienced on old GM products.
I am confused: what about a battery swap would cause this? I had the battery off for about 4 hours.
No SES light.
I understand that there is an adaptive idle relearn that may not have happened correctly, but does that explain the rough cold starting and possible backfires?
What should I check?
