Hard Starting Titan
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
capnjac
Car: 2010 Titan LE 4x4
Hi folks... hopin' someone has an answer. 2010 Titan LE 4x4 103k miles. Turn key, engine turns over but hesitates and is labored to start only for a moment. Once started, all is well. Battery checked out fine. No codes displayed. Answer please!! Thanks!
lexcrob
Car: I get a different ride faster than I could update this.
Really need just a bit more information to give you some ways to go after that.
How many cranks before she fires up?
Like cranks 8 times you give up cycle key again then just cranks 2 times and fires up?
Does it crank longer if say it was hot off the freeway and you ran in gas station then came back out to fire it up?
Based on just a hard crank condition you could be looking at a fuel system issue. Possibly a bad starter drawing too much. Maybe corroded battery terminations at the battery starter of grounding paths. If your up north this would be more likely.
Beyond that I just need some more feedback.
Good luck,
Rob
Return to “Nissan Titan Forum”
