Hard starting
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
daan
Car: 08 Nissan Versa S base
My 08, S, 6-speed Versa has just over 3000 miles, and all of a sudden it's having trouble starting, I have to crank on it for way longer than I used to to get it to fire up. Once it is running, everything is just fine but now it starts about as well as the 300K, 91 Mistubishi I was drivinbg before. It's due for an oil change soon, so when I take it to the dealer and tell them this, I'm sure they'll look at me like I'm a goon, unless this is a somewhat common problem. So, has anybody else had this happen to them?
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
It's a very common problem, discussed at length in many threads here. There is currently a service bulletin from Nissan about this calling for the dealer to replace the fuel pressure regulator. Call your dealer and schedule an appointment to get it fixed under warranty.
Return to “Versa Technical Discussions”
