Thanks for the reply macgiver. Yes, I have a new fuel filter, plugs, and wires. But I may just have to run new fuel hoses from the tank to eliminate the possibility of a blockage in the line. And as far as it being winter.. I'm in Miami, so a "cold" start is totally relative to your geographic location!macgiver wrote: ↑Thu Feb 22, 2018 6:14 pmmac , has filter been changed yet , because it's POSSIBLE that "cloggage" that settles and thickens due to overnight "Cold" , and "downtime" - juuuust opens up enough under a long protracted crank - whearas the "PULSES" of fuel (yes all the way from pump in tank through hose - squeeze hose @ idle you can feel this) churn they're way through = finally starts / runs and then warmed-up motor , coupled with jouncing around on road will keep this "OPENED UP PASSAGE" until next morning cloggage again . This sh#@t really happensNow it IS winter and assuming a very cold start another possibility is plug (s) have fouling (oil , carbon,coolant?) coupled with dew/condensation it can be an "extended crank" needed to get that situation going too
Just possibilities G T 2/22/2018
Well I know the FPR is good. I will try blowing air thru the line to clear any blockage. By chance do one of you fine gentlemen have part number for that check valve? I'd hate to drop that tank again, but I guess you could put a check valve anywhere in the li e before it gets to the engine. Thoughtsmacgiver wrote: ↑Fri Feb 23, 2018 9:10 ammac , I've see most chk valves keeping the prime to the motor all the way back near the tank , and what amc refers to is the more likely thing to lose "standing pressure" is - the pressure rgulator @ usually end of fuel rail that leaks back to tank will lose your prime . Now as amc mentioned ,getting into fuel lines etc. - be best to "blow through" , as a test & a "clear" .GT 2/23/2018
Already did the bleed test... and pressure stays good for more than an hour. But as said before if I prime a few times before I crank it she will start. Sometimes if there is too much fuel in there she revs up high and then shuts down. And you can smell the exhaust gas venting out of the air intake (got it open at the moment) After that she will start right up. Or if I spray a little starting fluid, she will start right up and run normally. Banging head on wall at this point.amc49 wrote: ↑Fri Feb 23, 2018 10:05 pmBlow forward to not damage any checking in there. You'll think you have a blockage if you blow backwards, the check(s) will seat and no flow. Dunno about Nissan but many domestic pumps have the checks right in pump outlet nozzle or in pump module lines. The FPR is the check up front.
Quick way to check if checks are leaking; a simple fuel pressure check, shut down motor and the pressure should not drop completely for say an hour, certainly not immediately.
