NISTECH wrote:Yea check the resistance on all 4 injectors when they are cold, also look for corrosion in thier conectors.
The checks are what needs to be done to find your problem. Do you have high idel when you start it or when it stops missing? Lack of air could cause it to run over rich when cold.
Yeah. I'll definitely do that this weekend. I'm going to hit everything I can with the multimeter. MAF, injectors, CTS. I'll also double check my timing ignition timing again.
I have a set of used injectors, so if I find one that isn't reading right, I can swap in another.
The idle is fine once it evens out. Normally it'll idle cold at abot 1100 rpm and then drop to 750 or so when warm. It idles steady, but when started warm it *nearly* stalls and then jumps back to a normal idle.
If I get really stumped, I'm going to get something (guy in australia makes 'em) that'll let me read and log a number of parameters through a laptop connected to the Consult port. Pretty neat tool for those of us who can't afford the $5K+ for the real deal.
Thanks, again man. I still wish I could persuade you to move up here to the Rust Belt. I need a good Nissan mechanic 'round here. Tell you what...I'll give you a free case of PB Blaster if you move to PA.
