hard start issue has begun
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
TryingDrive
Car: '91 Nissan 240SX (sileighty)
'08 Nissan Versa S 6spd
Soooo. Went on a trip out of state with my lady yesterday. And the dreaded hard start issue began. Did some searching and found people were having problems with the fpr. But did not find any info on its location. Have any of you changed the part yourself. My car is out of warranty. Thanks for any info
Francesco
It is under the rear seat on the passenger side inside the gas tank attached to the fuel pump. See if you can get service bulletin NTB07-094c.
Mine is also acting up but I plan to wait until I get closer to the end of my warranty period. It appears to me that after many years Nissan still does not have this problem permanently solved. In the meantime, I turn on the ignition as soon as I get in the vehicle and then buckle up and then try to start; this gives the fuel pump extra time to pressurize the system.
Frank
2009 Versa S sedan MT-6 with 19100 miles
ADOversa
Car: 2008 Versa S 6MT Hatch, 2005 Chevy 3500 LWB
I had this problem when I had only 8000km's on the car, issue was taken care of by the dealer. If there is some type of service bulletin on the car maybe they would cover it??
iluvmyVersa08
Car: 2008 Nissan Versa SL Sport
I had the issue too. Mine is an 08 model. Brought it into Nissan in Sept 09, and it was fixed under warranty.
Return to “Versa Technical Discussions”
