BlackJDMdeath »
https://forums.nicoclub.com/blackjdmdeath-u19031.html
Wed Aug 18, 2004 8:26 am
it has nothing to do with the engine, you aren't getting enough fluid pressure in the transmission. be it low fluid, clogged filter, bad pump, leak.... check you transmission fluid (do it correctly, if you don't know how, just speak up). if everything seems to be perfect (you check/change the filter, make sure she's getting fluid properly) it could be a bad band. it has absolutely nothing to do with your exhaust, injectors or any of that other stuff. you won't have a mixture of fluids being that no other fluids are there to mix.
