comatoseculture »
https://forums.nicoclub.com/comatoseculture-u118100.html
Fri Jun 04, 2010 1:01 pm
Hello. When getting used to a manual trans, it takes time, but in general getting smoothly into first gear, and then from first to second smoothly is much more difficult then the rest of the gears. That said, a lot of 240s (and a lot of other low buck low power cars) are put through a lot of low end abuse. IE hard/powershifting from 1st to 2nd, and as a result the syncromesh for second gear tends to be the most worn out. This is somewhat normal.
All that said, I suggest you just take your time learning. Dont expect to know more then you actually do and you'll find (through experimenting and so on) ways to make it shift at a rpm better suited for your worn syncros.
What are your intentions with this car?
