morselicious »
https://forums.nicoclub.com/morselicious-u172937.html
Thu Nov 21, 2019 3:03 pm
I have a 2015 Select. When you drive down the road at any speed and put your foot on the brake pedal to stop. As you press the pedal harder the front wheels skip, on brake, off brakes. Kinda hard to explain. Its like the front strut, cv joint, are broken and when you press on brakes the front end is twisting with a on brake hard then off. Like its holding the brake then letting go. Weird? No matter what speed you go it happens. When I took the pads off (front driverside) the rear pads on the driverside are worn at an angle, tho the outer pad was fine. When up on jackstands the driverside disc has a high spot you can see while spinning the disc. But, that doesn't seem to be the problem? I dont see any broken parts in the front end that might show wear. No Check engine light....ANY IDEAS???
