Kompresshun »
https://forums.nicoclub.com/kompresshun-u133574.html
Sat Oct 18, 2014 3:12 pm
Sorry for the delay in reply but welcome to NICOclub!
It will be hard to determine how much a shop will charge you, because it will all depend on their labor rates and how much of the line has to be replaced. Sometimes you can just replace a section and sometimes you have to replace the entire line. Most shops make the line from scratch unless it's one of the rubber lines at the wheel, so it will take them time to cut and bend the line, then flare it and install fittings. I guess if you want a really rough estimate, i'd say you're looking at around $500 without knowing for sure what they may try to hit you for on the repair.
