hard acceleration rattle
my09msport
Car: 2009 platinum gray Infiniti m sport
I've seen several post about the hard acceleration rattle. I had the same issue with mine, and had to get the y-pipe replaced and the catalytic converter(s). it took almost a year to trace the rattle down. dealers thought it was heat shields, loose exhaust tips etc. it took me going to a muffler shop to properly get the problem fixed..
Ilya
Welcome to the forum! And thanks for sharing. Hopefully this will help others with providing something they can look at.
Thank you!
my09msport
thanks for the welcome....I hope this topic helps someone because it took me a long time to pin point where the rattle was coming from on my car. it was very frustrating hearing it time after time.smh I'm so glad it's fixed.
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
Thanks for the post. I had another source of rattle from the same place. I turned out that I had picked up small rocks that were on top of the muffler heat shield in the course of normal driving. Their rattling around was causing a lot of noise. Once I figured that out and a way to clean them off my rattle went away.
my09msport
how did you clean the rocks out?
kmiles
Sold - 2007 M35x
I took off the plastic pan (under the spare tire) and then I could use one of those brushes for refrigerator coils to brush them all off. The plastic pan had about 20 small rocks in it that were rattling around, too. Once I cleaned all of those out, my rattles and noise from the rear end went away. It's been at least a year, so I'll probably do it again in the spring.
my09msport
ok thanks for tht information..I think I'll check tht area out and brush it out of it needs it as a form of preventative maintenance..I never want to hear rattles again lol.
