Harbody pedal assembly with sr20 5 speed
thenephilm
Is the 5 speed assembly in the hardbody's the same as in the 240sx in that everything will just bolt up without any major modifications?...Im putting a sr20 in an s10 and wanted to rob a pedal assembly from a nissan 240sx but if a nissan hardbody will work just as well then ill get that cause its easier to find...doesn't matter about length of pedals and whatnot, im moreso just concerned with the clutch master cylinder working fine with the sr20 transmission...if that makes sense lol...
cliffnotes...i need a nissan pedal and clutch master assembly to work with my sr20..will the hardbody's work without any trouble.
Thanks, Justin
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
the pedal bolts to the body, not the engine/trans.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
yeah, i am confused why you cant use a five speed s10 assembly. The nissans dont bolt together as one assembly and I doubt they will fit in your s10. peace.
