Happy Chrimbo Everyone!!
Larz
Car: 2019 Q70-L RWD
Just for your enjoyment. As Rugby gains popularity in the states, Here is an excellent mashup from Andy (England) of 25 brilliant moments in rugby, first played in 1871. In case you aren't familiar, you can NOT pass the ball forward - only behind you. You can only kick it or carry it to the goal and you must actually TOUCH the ball to the ground to earn a goal. Simply catching it inside the goal, or running inside the goal area does not count. The extra points are awarded when kicked over the crossbars from a place in line with where the ball touched the ground for the goal (called a 'try'). If you score in the corner, you must kick from the corner. No easy center line goal post kicks allowed.
Mjkkb2
Car: 2018 QX60 AWD, 2011 M37S, 2011 Quest, 2001 I30t(sold)
every time I see an American football game about to start I wonder if they finally bring out the motorcycles....But no - they just run around in helmets on the field :biggrin:
Thanks for the video and Rugby education....
