hankook ventus tires?
s0ldats
how do these tires perform? they're pretty cheap.....about the same price as dunlop fm9's
psyclone69
I had a set of 245/40/18 on my Grand Am GT I used to have, put about 10,000 miles on them, and sold them looking brand new.http://www.cardomain.com/id/psyclone69my old carThey gave me some awesome performance, I drove it harder than my 240, and didn't look like they wore a bit in over 10,000 miles.
s0ldats
so how do you think they'd stack up against dunlop fm901'S?
wanabe240esx
pepboys carries most ventus tires for only like 3-5 dollars over tirerack's prices, and pepboys doesnt charge shipping
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
Kick *** drift tires! I have them on the back and when I put them on the rim I had to run the pressure up almost 70psi before the bead set! Good side wall!!!!
s0ldats
so, i take taht everyone likes hankooks? how come they aren't as popular as the other tireS?
psyclone69
Not much advertising.
wanabe240esx
YamaOni wrote:Kick *** drift tires! I have them on the back and when I put them on the rim I had to run the pressure up almost 70psi before the bead set! Good side wall!!!!
damm, and i thought 63 psi was high
looks like you win Yama
YamaOni
wanabe240esx wrote:damm, and i thought 63 psi was high
That was to set the tire on the rim! The sidewalls on 50 series did not want to set! NO FLEX! and cheep = drift tires.* (*for the rear)
s0ldats
should i look for a more expensive tire for the front then? or can i just get all 4 hankooks (i don't like spending alot if i don't have to )
YamaOni
It depends on what you are doing.. Drag they are fine but, for drifting not so good you want the front tires to give a little in a corner, its scary when the front comes loose!
