I'm curious. You didn't mention which model tire you bought, nor did you mention if you had the suspension examined, wheels aligned after installation, etc.Frog wrote:An update on my hankook tires.
After 3 months of being unable to help them balanced, and I had a constant tire pull to the right no matter which way i rotated them. I returned them for michelin's cost me 850$ moreTreadwear was down to 8/10 of an inch in 3000 miles
I want to make this tire work but I just couldn't keep them balanced it was annoying at 65 to 75 mph.
Between the tread wear and the pulling, it sounds like you have alignment issues (which could also make it seem like you need to balance). Some tire shops are NOT good at alignment even though they offer it. For instance, where I live, I had my tires balanced at Big O tire shops several times (always poorly) before I learned that Tire Barn gives a great alignment (only because I bought tires there and didn't want to go to two places). My M45 never went straight on flat surfaces until I had Tire Barn align it (and my previous cars always pulled one way or the other as well).Frog wrote:An update on my hankook tires.
