Handling on Rainy roads??
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
Ok i have a question.. Like i know how my car handles and i know how to control the car when it looses control... (practicing in parking lots throwing it around alot helps) Now when i'm driving in the rain... My cars tail seems to want to come up from under me alot.. its an 89 240 FB... and i know how to control it so its not a problem but it seems it loose traction very easily.. now i have my system which weighs approx. 127lbs.. now i know that the cars weight ratio is 60/40 i was curious if that added weight would throw off my ratio and also cause it too loose traction in turns. Like in a straight line traction is not a probably.. its when it comes to merging on roads or taking right/let turns at green lights.... Tires are brand new.. and they are 215/65/R15.. on the back and 195s on the front.. i thought that the wider tire size would give me better traction.. :sad
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
just get better tires...size isnt necessarily a factor, look into falken azenis, i hear they kick *** in the rain and they're cheap...
that and learn to drive a lil slower :D
Thee 240sx Owner
No tickets.. lol wait that doesn't mean anything.. Umm I do drive slow..in rainy situations...
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
I use to have Nitto 555R's on my other car and they did not handle well in the rain. I would think that the tire’s ability to channel water away from the tire would be your biggest factor. The symptoms that you described were the same that I saw with my Nitto's.I would look into a good tire that is rated for wet conditions. I like my Yokohoma AVS DB’s.
Nismo_Freak
Car: 89 Nissan 240SX
Michelin Pilot Sport A/S for rain Falken Azenis Sports for dry
Don't forget suspension setup. Too stiff a rear setup (sway bar) can increase oversteer. Read a thread called "The Truth About Handling" by Q45tech in Infiniti Online Mechanic.
It should be required reading for ALL NICO members.
Thee 240sx Owner
You score another point AZ (you and your crazy deranged avatar changing s3lf :D) Thanks.. its very informative and it should be required reading.. Ha you should have it to where you register and make you read that and take a test on it then you can join... lol
Article Manager
The the truth about handling = article? whaddya think az?
Thee 240sx Owner
The car is completely stock btw.. no suspension work done what so ever.. just my system that seemed to throw everything off... I took it out and the car didn't loose traction that much.. i guess cuz it didn't have like a counterweight to swing it around more..
sammy
Car: cars, guns, music......the usual guy stuff
what is this thing you call rain?..........wet stuff used to fall from the sky here...........but not in many moons!!!!! lol
maybe you need to move to okla, then you can put your system back in with no worries
Article Manager wrote:The the truth about handling = article? whaddya think az?
Ab-so-root-ry.
Hasn't rained in Phoenix since March 7.
Beat that! :D
szh
Car: 2018 Tesla Model 3.
I'd recommend Firestone Firehawk SZ50EP tires for the absolute best wet weather handling performance you can get. Check out the specs/feedback on the web site of one of our advertisers:
http://www.tirerack.com/tires/...50+EP
Z
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
IT RAINED ON THE 11TH. IN GILBERT ANYWAYS. IT WAS LIKE THE TWO HOUR STORM OF A CENTURY.
Wish we got some of that. :(
Cold_Zero
It hasn’t stopped raining since July 5th here in Indiana. Every other day it rains. Sometimes God mixes it up and throws in a severe Thunderstorm.
Thee 240sx Owner
it doesn't rain here... it goes crazy.. and you can't see 2ft in front of you.. :( then it gets really hot to where we have fires.. then the hurrincanes come and then the illegal alliens wash ashore from the hurricane then we have to clean up.. and thenn i go drifting... what the hell did i just say here??
