rbboyl wrote:240s understeer? I thought rwd cars oversteer generally.
Pretty much all cars will understeeer if pushed too hard. Imagine coming into a turn 50 mph too fast. Try to turn the wheel as hard as you can. The tires will not grip enough to turn the front end in as fast as you would like. So...you end up with understeer.
The 240sx is fairly well balanced, but we have a crutch that is referred to as a Macpherson strut in our front suspension. Not that it's not well engineered, but it's not optimal for handling. Unfortunately, it does not change camber enough as you corner. You'll end up running on the outer edge of your outside tire. I've actually ripped away small chunks of the tread that's right against the sidewall when driving around a race track. My last set of tires wore the outer edge before the inner edge. I've gotten camber plates since and the difference is quite noticable. Running about 3 degrees of camber, it has very little understeer.
And as far as trying to power out, many times, if you are understeering heavily, adding power will actually increase understeer. Go to a track. Everything you thought you knew about handling will go out the window.
