97BlkMaximus »
https://forums.nicoclub.com/97blkmaximus-u140161.html
Thu Aug 06, 2009 3:12 pm
Never seen one bent, but you CAN pull them too hard.I found this out the hard way. "Drifting" around a parking lot one day I ripped my e-brake extremely hard, putt it down, and started the drive home.
Halfway there, about 3 miles later, my buddy who was driving behind me in his 95 Crown Vic called me and said, "DUDE, your car smells like s*** and is smoking..." So I pulled over asap into a parking lot. Got out, after engaging the e-brake one more (but as I pulled I noticed it was alot easier to pull and went up much farther), if you can guess it by now, yes, my driverside e-brake cable/pin puller thing got stuck on and ROASTED the crap out of my left rear rotor and pads. Had to get under the car and manually dis-engage the e-brake puller/cable by hand (or screwdriver rather) and drive home.
Long story short, I DON'T USE MY E-BRAKE ANYMORE. Even after fixing the cable, tightening it back up, and greasing the pins I ONLY keep my manual in gear when im stopped.Only when those once in awhile times come along when you have to keep your car running and not moving do I use it.
Its not that no one uses it anymore, I don't know why the F that guy said that, I just don't use it because im scared. Haha.
Use it if that's what your used to, just make sure it doesn't get stuck on, by no fault of your own.And take it easy on that handle! Those teeth that it clicks into will wear if you rip it to often or fast! Hold the button down and only pull till it feels tight but not impossible to let down.
