deerio,
Okay, I do not think you need these parts. Starting from the driver side cab where the cable comes through the floor -
To the center line of the truck in front of the cross member -
This is where the part cluster should be.
Center line of truck behind the cross member -
And from here the emergency cable goes to the left and right rear drums.
As you can see my '65 does not have these parts either. If it did then this cluster of parts would go from the cable, Assembly, Hand Brake, Middle (36444-08701) to the Assembly Arm Center Link (36421-08701). This might be for a Right Hand Drive model, but you would think the parts would be marked accordingly.
v/r
Andy
